TwinTurbo.NET: Nissan 300ZX forum - Dumb question, is timing belt new?
njz
on February 21, 2011 at 8:56 PM
New auto-tensioner failure?
posted by spyder46
on February 20, 2011 at 07:30 PM
Did not see you note new belt.
spyder46
19:30:04 02/20/11
You are setting it too tight. (n/m)
Woody75 (Denver)
21:11:55 02/20/11
Re: You are setting it too tight.
spyder46
21:28:17 02/20/11
Would assume the tensioner was OEM? If so, scary if
jzack
22:35:48 02/20/11
The tensioner is oem, I'm wondering if there is
spyder46
23:17:50 02/20/11
aside from normal valve spring tension
aliaZ
23:43:26 02/20/11
after the first slip there was no binding
spyder46
23:59:42 02/20/11
I will be pretty pissed if there recent ones are bad, I just
JonnyZ(SoCal)
02:48:30 02/21/11
Dumb question, is timing belt new? -
njz
20:56:14 02/21/11
No questions dumb if it helps fix the problem
spyder46
22:38:42 02/21/11
A Gates belt? Heard they are different, go buy Nissan OEM (n/m)
Zinn2win
10:39:57 02/22/11
